ARBRE MAGIQUE: taglio feltro di 2mm con iCraft
Caricato materiale su tappetino viola.
Ho usato entrambe le punte per prova:
Punta fine
  1. Materiale Feltro 1mm
  2. Aumentata FORZA a 9
Punta profonda
  1. Materiale Pelle artificiale
  2. Settato spessore a 2mm
Eseguito foro con pinza foratrice.
Profumato a piacere!
Loaded material onto purple mat.
I used both tips to test:
Fine tip
Material Felt 1mm
Increased STRENGTH to 9
Deep tip
Material Artificial leather
Set thickness at 2mm
Drilled hole with drilling pliers.
Scented to taste!
Hi welcome to the community if you could please translate your post into English it would be better for all the members :blush:
And nice project you have made :+1:t2:
Same. I was searching if there is an auto translate button. And those trees are cute.
Is thag a car freshen3r? How did you put freshner in you materials?
There isn’t yet we have demanded that last month and we hope they’ll be able to make it
Punta fine
Punta profonda
Fine tip
Material Felt 1mm
Deep tip
Scented to taste!
