Cutting embossed real leather
This will be my first time to cut leather not leatherette. It is such a beautiful piece I don’t want to screw it up and I don’t have a piece I can practice on. Would you mind giving me all the tips I need?
thanks
Michelle
Hello Michelle! :wave::smiley: I haven’t cut real embossed leather on the iCraft before, so I want to be upfront with you — the machine isn’t really designed for thick, dense, genuine leather. It can sometimes handle very thin, soft leather, but embossed leather is even trickier because the raised texture changes how the blade drags. Since you only have one sheet, I want to help you protect it as much as possible.
Before I can point you in the right direction, can you tell me how thick your leather is? If you know the millimeters or the ounce weight, that helps a lot. Even a rough guess (super thin, medium, or thick/stiff) is better than nothing.
Here are the things you’ll want to keep in mind:
  • You must do test cuts. There’s no safe way to skip them with a material the machine wasn’t designed for. Even a tiny ½‑inch corner is enough to test — and you’ll save yourself from ruining the whole sheet.
  • Real leather needs to go face down on the mat, and should be taped down with painter’s tape so it doesn’t shift. Mirroring is recommended.
  • Use a StrongGrip mat and press it down really well. Embossed leather likes to lift.
  • Start with a deep‑point blade, high pressure, slow speed, and 2–3 passes on a tiny test shape. Don’t unload the mat until you check if it cut through.
  • If it didn’t cut all the way, add 1–2 more passes. If it’s cutting too deep or tearing, back the pressure down.
  • Even if the machine cuts 80–90% of the way, you may need to finish the edges with scissors or a craft knife. That’s normal for real leather on a non‑knife‑blade machine.
  • If the leather is thicker than about 1–1.2 mm, it may not cut cleanly at all — in that case, the safest option is to cut a cardstock template on the iCraft and hand‑cut the leather using that as your guide.
I just want to help you get the cleanest result without risking your only sheet, so once you tell me the thickness, I can help you narrow down the safest approach.
