Because knowledge shared is creativity multiplied.
Today’s mission is about more than making something. It is about making it understandable for someone else. Teach It Forward challenges you to create a project with the intention of teaching the process to another member of the community, whether they are brand new or simply trying a technique for the first time.
You do not need to be an expert or a professional instructor. You simply need to be one step ahead and willing to share what you know. Teaching forces clarity, strengthens your own skills, and helps build a stronger, more confident community.
The Goal of Today’s Mission
Choose one process you regularly use and walk through it as if you were explaining it to a friend sitting beside you. The focus is not speed or perfection. It is clarity, simplicity, and documentation.
Step 1: Simplify the Process
Simplifying means removing unnecessary steps, jargon, and assumptions.
Best Practices for Simplifying
Focus on one outcome, not multiple variations.
Use plain language instead of technical terms whenever possible.
Eliminate optional steps unless they are truly essential.
Break the process into small, logical stages.
Example Processes to Simplify
Sublimation on tumblers:
Focus on one size such as a 20oz straight tumbler, one paper type, and one press setting.
Vinyl cutting and weeding:
Focus on one vinyl type such as standard HTV, one machine, and one simple design using a single color.
Laser cutting a layered design:
Focus on one material such as 3mm birch plywood, one file type, and one assembly method.
Simplify by asking:
What does someone need to know to succeed the first time?
Step 2: Clarify Each Step
Clarifying is where confusion disappears. This is where most teaching breaks down because steps get skipped since they feel obvious to us.
Best Practices for Clarifying
Explain why a step matters, not just what to do.
Call out common mistakes before they happen.
Use measurements, temperatures, times, and settings explicitly.
Use directional language such as top and bottom, left and right, face up and face down.
Example: Clarifying Sublimation on a Tumbler
Instead of saying press the tumbler, clarify it by explaining how to wrap the design seam to seam with firm pressure, tape tightly so there are no gaps or air pockets, place the tumbler with the seam facing away from the heating element, and press using the recommended time and temperature for your specific press.
Clarification builds confidence. When someone understands why they are doing something, they are far less likely to panic when something looks different than expected.
Step 3: Document the Process
Documentation turns knowledge into something repeatable.
Best Practices for Documenting
Write steps in numbered order.
Take photos or short clips at key stages.
Capture settings and materials used.
Note any adjustments made along the way.
What to Document
Vinyl projects
Machine brand and blade setting
Vinyl type
Cut settings
Weeding tips
Heat press projects
Temperature
Time
Pressure
Warm peel or cold peel
Laser projects
Material type and thickness
Power and speed
Assembly order
Glue or finishing methods
Even a simple notes app or handwritten list is enough. Documentation does not have to be fancy to be valuable.
Step 4: Teach with Empathy
Remember that someone learning this process may feel intimidated. Teach as if you are standing beside them, not above them.
Teaching Tips
Share one mistake you made and how you fixed it.
Reassure learners that imperfect results are normal.
Encourage experimentation after the basics are mastered.
Avoid phrases such as everyone knows or it is obvious.
Teaching with empathy creates safe learning spaces, and those are the communities that grow the strongest.
Community Challenge
Share what process you would choose to teach, one step you would simplify, one detail you clarified that people often overlook, and one thing you now understand better after explaining it.
Bonus points if you include a photo, checklist, or short written guide someone else could follow.
Why This Matters
When we teach, we do not lose our edge. We sharpen it.
When we share knowledge, we raise the skill level of the entire community.
And when we document what we know, we turn creativity into confidence.
Today, do not just make something. Teach something forward.
