Easter Bunny Magnetic Keychain Holder
Easter Bunny Magnet Keychain Holder Tutorial Materials:
  • 5mm Rigid Sintra (you can also use a lighter Sintra, like 3mm, if you want to cut it manually)
  • Sticker paper (90gsm)
  • Glittered photo top
  • Cutter
  • Scissors (manual)
  • 2 pcs Magnets
  • B-7000 Glue
Design:
  1. Choose your design: We’ll start with a bunny from Pinterest. Add some Easter eggs and carrots in the background. You can use Canva to create this design.
  2. Print your design: Print the design onto sticker paper.
Assembly:
  1. Add the photo top: Carefully cut the glittered photo top to size and attach it to the front of the Sintra.
  2. Cut your design: Carefully cut out the bunny, eggs, and carrots using scissors. If you have a Loklik cutting machine, you can upload the design and cut it using that method instead.
  3. Prepare the Sintra: Cut a piece of Sintra that’s slightly larger than your design.
  4. Cut the Sintra: Use a cutter to carefully cut out the Sintra, following the shape of your design.
  5. Make a hole: Use a drill or a hole punch to make a hole in the Sintra to attach the magnet. Make sure the hole is aligned with the bunny’s design.
  6. Attach the magnet: Put a dab of B-7000 glue onto the magnet and then attach it to the back of the Sintra, inside the hole you made.
  7. Add the sticker: Carefully peel off the backing of your printed design and stick it onto the Sintra.
  8. Attach the carrots: Repeat steps 6 and 7 for the carrots, using the same method to attach them to the Sintra.
  9. Cut the Sintra Board
Important Notes:
  • Cutting the Sintra: Use a cutter to cut the Sintra, making sure to use a firm but steady hand.
  • Magnet Size: I used small magnets that can hold lighter objects, but you can use stronger magnets if you want to hang heavier items.
Let’s get crafty!
I’ll be posting a video here so you can hear the clicking sound of the magnets
Wow so cute :smiling_face_with_three_hearts:
Thank you so muchhh
So cute.Go Girl🥳
Thank you so muchhh
I agree,The design is absolutely stunning.
Thank you! It really is impressive—I’m so glad you think so too
Wow this is so cute!:heart_eyes:
This is so cute and creative :heart_eyes:
I love the bunny such a cute creation
Thank you so much
wow amazing very creative work.
This is so cute :heart_eyes:
happy little bunny
