can anyone tell me does it have to warm up first before the green light comes on because my white on and off switch flashes for ages before it comes green .
Hi and Welcome to the Community @Geraldine_Broadhead!
Yes, the HTVRONT Auto Heat Press does need to warm up before the green light turns on. That flashing white power switch is totally normal—it’s just letting you know the machine is heating to your set temperature. Once it reaches the target temp, the light turns green and you’re good to go! ![]()
If it’s flashing for a really long time or doesn’t turn green at all, it might be worth double-checking your temperature settings or doing a quick reset. But in most cases, it’s just part of the warm-up cycle. Hope that helps!
Welcome @Geraldine_Broadhead great question and thanks @rinsky for the great information about the warm-up process for the HTVRONT Auto Heat Press. I am currently awaiting my delivery and find this to be a helpful tip!
Aww, thank you @LAJUANA_ANTHONY! I’m so excited for you—there’s nothing like that “new machine” anticipation!
You’re going to love how easy the HTVRONT Auto Heat Press makes things once it’s all warmed up and ready to go. If you ever run into setup questions or want tips for your first few projects, I’m always happy to help. Can’t wait to see what you create! ![]()
