How to Print Solid White
Hi all, I need to print a solid white design… when I send out to print through RIIN, it does not print. The machines moves as if it was printing but nothing prints. Has anyone found a way to print solid white for their dtf prints? Thank you!
Hello, @Brav_3. :wave::smiley:
Here are some things that you may need to try:
Create White Underbase: Your design must have a dedicated white layer in the RIP software; the printer won’t add it automatically.
Enable White Ink: Check your software settings (like Acrorip) to make sure the white channel isn’t disabled, defaulting to grayscale, or skipping white ink.
Agitate & Check: White ink settles; gently shake cartridges and run a nozzle check to confirm it’s flowing correctly before printing.
You can also check this article out and see if it helps: Why Is My DTF Printer Not Printing White.
If this doesn’t work, come back and we’ll see if we can get you some more help.
