HTVRONT H10 Heat Press Hands-on Review – Part 2 Testing Printable, Glitter, Puff, Classic HTV and DTF Transfers
Printable HTV, Classic HTV, Glitter HTV, Puff Vinyl & DTF Testing
After a strong start in Part 1, I moved into hands-on testing with printable heat transfer vinyl, glitter HTV, and puff vinyl. The H10 continued to impress with its consistent heat, intuitive controls, and ergonomic design. I had a few hiccups—mostly due to user error—but each one taught me something new. The more I use this press, the better each project gets.
Printable HTV: Learning Curve + Recovery
• First attempt: I pressed a printable HTV design onto a baby onesie using vinyl not intended for easy press-style machines. In my excitement, I started to press before I even knew how to start the timer, so I let the machine sit too long before starting the timer, then re-pressed which resulted in cracking.
• Second attempt: Another onesie had one area that didn’t adhere. I suspect uneven pressure due to pressing on a surface that was too high. Due to the fact that it was the bottom of the “A” in “Answered” which was on the far side of me, it had to be that I wasn’t adding even pressure across the board.
• Success after adjustment: I switched to pressing on my desk, which sits just below waist level. That gave me better leverage and more even pressure. The next two onesies pressed perfectly.
Glitter HTV: Sparkle + Strength
• Adhesion: Pressed beautifully at 300–320°F with medium to firm pressure.
• Minor hiccup: One tiny corner of the star lifted during my first press. After 2 re-presses, I decided to just use my mini press, as I didn’t want to scorch the rest of the design. I don’t think this was the fault of the H10, I believe there may have been some lint under the vinyl, as I, admittedly, forgot to lint roll this shirt before pressing, or it could’ve been the vinyl itself. I’m betting on lint, though.
• Project highlight: A beautiful kids’ tee that reads “Cookie Tester Reporting for Duty”—all glitter HTV, all sparkle.
• Mixed media success: An adult tee that reads “It’s the Most Wonderful Time of the Year” using mostly glitter HTV and a patterned classic HTV for the Christmas tree. Both vinyls pressed cleanly with no lifting or dulling.
Puff Vinyl: Texture + Technique
• Expansion consistency: Puff vinyl rose evenly across the design at 300°F.
• Layering method: I tack-pressed the glitter vinyl for 5 seconds, then added puff vinyl and pressed for the full 10 seconds.
• Minor hiccup: I used heat-resistant tape to hold the puff vinyl in place, but left a folded tab (which I do to make it easier to lift the tape from the roll) sitting on the carrier sheet, over the vinyl. That tiny bump disrupted pressure, causing one small area to have a smooth puff instead of a textured puff. Lesson learned: either trim the tape tabs, or make sure it’s not laying over the carrier sheet when taping it in place.
DTF Transfer: Smooth and Reliable
• Press performance: The H10 handled the DTF transfer beautifully. Heat and pressure were distributed evenly across the design, with no weak spots or inconsistencies.
• Cold Peel success: After one clean press, I let the design cool and did a cold peel. The transfer released smoothly without tugging or residue.
• Final seal: To finish, I laid a T-shirt over the design and gave it one last press. This sealed the transfer perfectly, adding durability and a polished finish.
• Result: Crisp edges, vibrant color, and a professional feel—no hiccups at all. The process was straightforward, and the H10 delivered exactly what I needed for a flawless DTF application.
Safety & Batch Pressing
• Cool-touch top: Despite the “Caution: Hot Surface” label, the top of the press stays cool for a long time. Even after being on for awhile, it only ever gets slightly warm. Also, with the 15-minute auto shut-off, I can rest assured that it will turn off, if I leave it on and leave the room, which I did do a couple of times.
• Large, unobstructed display: One of my favorite features is how the digital display stays clearly visible even while pressing. The handles don’t block the view, nor do I, so I can monitor temperature, pressure, and timer in real time without shifting position or breaking focus.
• Batch pressing: I did two back-to-back presses during this phase of testing. The H10 held its temperature, didn’t overheat, and stayed consistent. I’ll be doing more batch testing in Part 3 to see how it handles longer runs.
• Ergonomic win: The dual handles make it easy to apply pressure without straining my wrists. They make it easy to lift the press away from the base, keeping my hands safely away from the heating element.
What’s next: Part 3 Preview
In Part 3, I’ll be testing classic, glitter, chameleon, and puff HTV on canvas and wood surfaces, plus:
• Exploring pressure adjustments for textured and rigid materials
• Tracking heat recovery and consistency across batch pressing sessions
• Sharing tips for adhesion, edge coverage, and workspace setup
• Light wash test to see how well the vinyl holds up after a wash
I’ll also be posting a link to the YouTube video I’ve been working on for this review. That way, you’ll get to see the full hands-on experience.
If you’ve got questions or want me to test a specific material, let me know—I’m happy to include it, if I have it available, of course.
Amazing test! Very detailed and each demonstrates how easy and amazing this press is and how convenient it is as well! Love!!
Very well executed review!
Thank you so much, Amber! :heart: I’m glad the details came through clearly—it really is such a convenient press to work with. I love being able to share tests that make the process feel approachable and fun. Your encouragement means a lot! :smiling_face_with_three_hearts:
Amazing review Samantha! :sparkling_heart:
I love that you included the hiccups I definitely had some when testing out too! But this was incredibly well put and I can’t wait for your next part :two_hearts:
Thank you so much, @DianeB! I think sharing the hiccups is just as important as the win. It makes the process real and helps us all learn together. I’m glad you could relate to those moments too! I’m excited to share the next part soon. :heart:
Amazing review and beautiful projects :heart_eyes:
Thank you so much, @Marino ! :heart: I’m so happy that you enjoyed both the review and the projects. I had so much fun making them. It makes all the effort that I put into it all worth it— knowing that fellow creators enjoyed my work. :smiling_face_with_three_hearts:
Great review. Love the puff vinyl
Thank you so much! I’m happy you think so! :heart: Yes, it was my first time trying puff vinyl, and I was a little nervous going into it, but it worked out great, for the most part. :laughing: The H10 made it so easy to jump right in and did an excellent job on the puff. I’m the one who caused the hiccup, but now I know what not to do. :joy: I’m excited to do another puff vinyl test — without the hiccups.
I absolutely love this! Such an awesome review, and now I’m totally inspired to get one too, lol.
:sparkling_heart: That makes me so happy to hear! It really is such a fun and convenient press. I’m glad the review inspired you. :hugs:
Thanks for the review.
Really great review and amazing projects so far. Can’t wait to see part 3 and your YouTube video. Very well done, thank you so much
Thanks so much, @Katrina_Moore, @Mary_Williams, & @BellethehowtoGuru! I’m happy you liked my review! :heart: I spent all week working on part 3. I can’t wait to share with you everything I did with it. Had some fails—due to user error, of course—but had many successes, as well! :smiley: I’m so tired after this week! But it was so worth it.
