Ipaint question
How do you erase lines that you do not want on the canvas?
Sometimes I just paint the canvas :sweat_smile: :rofl:
on the digital software canvas where you change the size…can you get rid of unwanted contour lines? before printing to the real canvas. There is a tree i would like to remove.
I don’t have the iPaint, but I read somewhere that you can erase the ink with heat. Provided you’re using the pens that are made for the iPaint.
Edit 1: Oh, nevermind, I misunderstood your question. You may be able to ungroup the whole drawing, and select the specific line you want to remove and delete it. Or you can try using the Combine > Split to break them up, if the ungroup doesn’t work. However, this is a theory, as, like I said, I don’t have the iPaint, so I’m not sure if it will work the same as it would using my cutter.
Edit 2: I just uploaded a colored pencil drawing of mine, and used the Line Art option from the Image Matting panel. I was able to ungroup and select specific lines and delete them. However, the Split tool stayed grayed out. So, you may try the ungroup option. Please, let me know if this worked for you, so I’ll be able to help others if they ever post a similar iPaint question. I’d appreciate that so much. Hope it works! :heart:
