LokLik printer software and drivers
Hello, I received a usb drive with my printer but nothing is on it and I can not read anything on it. I downloaded RIIN online but I have not gotten my printer to talk to my computer. Also I saw another software program on this site “Better Printer hlc” but I can’t find it online. Please help.
*Hi and Welcome to the community @Paula_Newell! Thanks for reaching out! It sounds frustrating to get a blank USB and then hit roadblocks with setup. You’re on the right track downloading RIIN, but connection issues can sometimes come down to driver compatibility or USB settings.
:hammer_and_wrench:Here are some guidelines for RIIN Printer Connection Troubleshooting Steps
1. Check USB Connection
  • Use the original USB cable that came with the printer.
  • Try a different USB port on your computer—preferably a direct port, not through a hub.
  • Avoid using USB-C adapters unless necessary; they can sometimes cause communication issues.
2. Install RIIN Properly
  • Make sure you downloaded the latest version from the official LokLik site or community thread.
  • Run the installer as administrator (right-click > “Run as administrator”).
  • Restart your computer after installation.
3. Verify Drivers
  • Open Device Manager (Windows) and check under “Printers” or “USB Devices.”
  • If you see a yellow warning icon, right-click and update the driver.
  • If no device appears, try reinstalling RIIN or using a different USB cable.
4. Printer Power & Mode
  • Ensure the printer is powered on and not in sleep mode.
  • Some models require you to press a button to enter “PC connection” mode—check your manual.
5. Software Settings
  • Open RIIN and go to “Settings” or “Device” tab.
  • Select your printer model manually if it doesn’t auto-detect.
  • Try refreshing or rescanning for devices.
6. Firewall & Antivirus
  • Temporarily disable firewall or antivirus software—they can block RIIN’s connection.
  • Add RIIN as an exception if needed.
7. Missing USB Content
  • If your USB drive is blank, check if it’s formatted correctly (FAT32).
Hope it helps! If nothing works, I’d recommend reaching out to support directly—they’ve been responsive with setup help.
Hi there, please feel free to reach out to support@htvront.com and our support team will arrange to send you the software installation package you need. We truly appreciate your understanding and patience. :heart:
Welcome to the community @Paula_Newell !!
@rinsky never fails! Please read her advise and contact support too, as @OliviaZzz said.
I hope you can solve the problem soon. Please, let us know xdd
