Print and cut calibration
Hello Everyone! I am new here. and a beginner in icraft. Do you have tricks on calibrating print and cut ? Please do help. thankyou so much foe your advices!
Hello! I used a colored pen instead of the blade so I can clearly see which line is most centered. This really helps me determine the most accurate calibration point.
This is a great idea!! I will definitely try this one. :heart_eyes: thankyou so much!
This is interesting knowing that the two holders do the same work, thank you.
yessss i never thought of this.
I had thought about it, but never tried and had my doubts. I see it very interesting particulary to explore folding marks with the crafter xddd
I want to try this now haha. But noooo, maybe later
:joy: let us know
dfntly
Clever :heart_eyes:
my tips would be to use the USB cable, check that your firmware is up to date, and then run the calibration.
ohh I havent updated mine. I am a little worried about the app crashing
no need to worry Sara, it won’t crash it will make everything work better :dizzy:
There’s a heap of tip in this post
Don’t worry about that. Mine even got to die when I first updated it and there’s no problem, the flash tool just reload the firmaware and works again but better. The firmware improves quite much the performance.
thankyou!
