I have also holographic stickers paper im definitely going to try it and see how it will read the registration marks ![]()
Good luck on that
I think I’ve only managed to do it twice on my Crafter. I also blocked the fron part of the machine leaving only a tiny gap for the mat and material to pass through or closed the room lights to make it completely dark. ![]()
Yeah that’s the trick
I put my crafter under my maker so the lid won’t open and it’s already dark so I’ll cross my fingers ![]()
May I know which site is this?
Oh, I’m from the Philippines, it’s froma local shopping app here. I’m not sure if they ship internationally
Ok, thank you for the information.
Temu is almost available all over the globe, if you don’t have it maybe try shoppee or lazada if your in the Asia region
Thanks, I knew about these sites before but I wasn’t sure if they were safe or not. I’ll try this
They are pretty safe to be honest, but just keep monitoring your accounts. Should you see anything unusual. I’ve been using that for quite a while now.
I have reviewed both sites. However, as far as I understand, unfortunately neither of them ship to European countries. I wanted to inform other users.
They are currently working on this at the moment. We have put this information forward to them and they’re working really hard to have this sorted. So do not worry it will take some time But the website will eventually be open to EU residents.
Print and Cut with the Loklik Icraft ![]()
I layout first my stickers at Canva using A4 size then save as PNG. I limit it to 5mb so Loklik can read it when uploading.
Usually my stickers became small so I still need to resize it to fit an A4 material.
Select then Make - Print and Cut.
Print the stickers. I put a Matte Photo Top on this Glossy Stickers.
Force - 11
Speed - 5
Pass - 2
Hope this helps.
Even the tiniest details can cut—each precise slice of the Loklik machine reminds us that true beauty is crafted in the details.
Good job on the Icraft! Thanks for sharing! ![]()
Yes I’m amazed how the Icraft can cut small details in a perfect way ![]()
sometimes there is a miss but most of the time it is perfect! <3
One of my favorite projects is making cute stickers ![]()
