Project | Big thank you!
Made with soft pastel purple cardstock, this card has an elegant, boutique-style feel. The decorative front panel features intricate cut designs layered over coordinating cardstock to create depth and dimension. A bright pink satin ribbon tied at the top adds the perfect pop of color and a handcrafted finish
The message inside — “Thank you Loklik and HtvRont for a wonderful community” — was created using the LOKLiK iCraft pen drawing function, giving it a smooth, professional look directly on the cardstock. The detailed cuts were done with the LOKLiK iCraft cutting machine, showing just how precise and clean the machine performs with intricate designs.
This card is perfect for vendor appreciation, community shoutouts, or small business thank-you gifts.
Brief Step-by-Step Instructions
1. Design in LOKLiK Idea Studio
Choose a layered card template and add your message. Select an elegant serif or script font for a polished look.
2. Set Up Pen Function First
Insert the LOKLiK pen and run the drawing function to write your message on the cardstock before cutting.
3. Cut the Card & Decorative Layers
Switch to the blade and let the LOKLiK iCraft cut the card base and detailed overlay pieces.
4. Assemble the Layers
Use adhesive to attach the decorative cut panel onto the card base.
5. Add the Ribbon
Thread or glue the pink satin ribbon and tie into a bow for a soft finishing touch.
Simple materials — but with the right tools and creativity, it turns into something elegant and meaningful
This is very thoughtful and inspiring
