What’s better on a spring day than nice warm breezes? Gardening …. yep …. gardening. So pull out the rake, clear your spot, brab the shovel and dig a hole, put your flowers in with the trowel , and some good chemicals and fill your hole back up.
Materials Used
Shadowbox … purchased or made
Cardstock (assorted colors)
Cutting Machine
Scissors
Foam spacing pieces
Cardboard for backing piece if not provided with shadowbox
Glue
Steps
Measure the shadowbox opening and adjust the contents to the measurement minus 1/8”
Cut everything in multiples of 2 except for the bench … cut 5 and the fence cut 1 front and 1 back piece, cut 1 blue background piece
Glue your background color to the shadowbox backing (mine is blue)
Assemble your fence with the front and back layers with foam spacers in between
Glue your fence to the back wall
Assemble the bench first as follows: 2 complete pieces, 2 bench on down, 1 piece just above the legs trimming with scissors where needed.
Add the watering can, boots, and flowers to the bench
Add your bench in front of the fence with foam spacers according to the picture
Assemble the rake and shovel and place in the scene
Assemble the trowel, hand rake and pot and place in the scene to finish
(upload://kqQB1RNa1bQOMXctzLMtV9uEAcz.jpeg)
(upload://2nIMPlyygrgFkVhWZA2WQTadE5h.jpeg)
