Hi has anyone sublimated glass coasters? If you have what time and temp did you do them on?? Also how many mats did you use? I am using the impress auto V1. Any help will be apparated.
Hi! I haven’t tried the sublimation on glass coasters yet, but I did some glass cutting board (uncoated). Just wondering if you bought coated glass coasters. I did press mine with a laminate sheet first at 400 F for 60 seconds with 70lb pressure (light pressure) and a second press with sublimation paper with the same settings. I used the mat in my Auto Heat Press 2, layered it with cardstock and butcher paper on top of the design to protect heat plate from ink. Also, you can always check the manufacturer’s setting if you have coated glass coasters and with your heat press. Then adjust accordingly Hope it helps as your reference.
Wow! this is so pretty
Woooow, tha’s so prettyy
That looks so pretty
