Nameplates in thin acrylic for a confirmation party
That’s insane, all the ideas you guys come up with! Is that engraving? I´m curious about the process.
They look fancy
That’s so pretty. Did you cut out the circle? Is that vinyl for the words?
Wow😮How thick is the acrylic?
its not engraving. i was sad to find out the loklik did not have the engrave function (yet ).
I used the finepoint blade and the material option was some kind of stencil in the Others tab.
the circle(nameplate) is from temu or shein & the words was cut with the finepoint blade
the acrylic is 0.2mm
i set the pressure to 7 and cut 1 time.
I was wondering if the blade might have done so. Thank you to let us know the details
