If there’s one project that has completely captured my creative heart, it’s shadow boxes. There’s something so magical about layering art — building depth, emotion, and story one piece at a time. Each one feels like a little world frozen in a frame.
When I first started making shadow boxes, I didn’t realize how much thought goes into balancing color, depth, and texture. Over time, I’ve developed a process that helps me bring my ideas to life while keeping that handmade charm that makes every piece special.
Here’s a peek into my creative process:
Choosing the Theme
Every shadow box begins with a story — a feeling, a memory, or even just a single word. For example, my “Thankful” Boho box started with the idea of gratitude, and everything else — from color to layout — built around that emotion. The theme sets the tone and helps guide design choices down the line.
Designing the Layers
I use design software to plan out the layers, thinking about how each cut will interact with the next. I love mixing clean silhouettes with delicate details — it creates contrast and depth.
Tip: Keep your background simple if your top layers are intricate — the eye needs space to rest.
Choosing Materials
The type of material changes the entire feel of a piece. For most of my boxes, I use premium heavy cardstock (110lb) cardstock, depending on the design. Cardstock offers crisp color and texture variety. The addition of glitter cardstock and foil cardstock help to accentuate layers that you want to standout in the background.
Cutting & Assembly
This is where the LOKLiK iEngrave Laser or your cutting machine shines! I use it for precision cutting, engraving fine details, and ensuring clean edges that layer perfectly. Once the pieces are cut, I use foam spacers to separate each layer, creating that stunning 3D depth that brings the design to life.
Pro Tip: Test your spacing before gluing — subtle depth changes can make a big difference in how light and shadows play across your piece.
Finishing Touches
This is my favorite part — adding embellishments, painted accents, or even a dusting of shimmer. I sometimes use my HTVRONT Auto Heat Press for adding vinyl quotes or sublimated backgrounds, giving each box that extra professional polish.
Displaying the Story
The final step is framing and lighting. A soft LED strip behind the last layer adds warmth and dimension, especially for winter or holiday designs. When that light hits just right, it’s pure magic!
Shadow boxes are more than just décor — they’re keepsakes, memories, and reflections of the moments that matter most. Each one tells a story, layer by layer, just like our crafting journeys.
So if you’ve never made one before, give it a try! Start small, choose a theme that means something to you, and let your imagination build the rest. Trust me — once you make your first, you’ll be hooked.
