Adhesive Vinyl need help 😅
Now I need help :sweat_smile:
For this daily-mission I need your help in installing adhesive vinyl during humid weather.
I tried putting some halloween decor on our glass sliding door. Before applying, I wiped it down with alcohol 1st to clean it then wiped it with tissue paper. I thought it was already dry but when I tried applying the vinyl, the thin cuts wouldn’t stick. And when I touch the glass, I still felt a bit of moisture.
After a while there was a thunderstorm.
Now I left the transfer tape on the vinyl :sweat_smile::woman_facepalming:
Hoping it will adhere tomorrow.
The ghosts :ghost::ghost: though were able to stick. They were cut on the same vinyl sheet.
What tips do you have for me please? :pray:
Maybe a blow dryer…. On low or cool hair to dry the area and vinyl :woman_shrugging:
Thank you for this. I’ll try it out tomorrow :smiling_face_with_three_hearts:
It shouldn’t be the humidity because there is
the wet method for applying adhesive vinyl without bubbles I guess you need to press down or swipe it with the squeegee and let it sit for a while then peel the transfer tape.
Also a blow dryer or a heat gun is a good idea.
Thank you for these tips. I haven’t tried the wet method yet. Will try them again tomorrow :smiling_face_with_three_hearts:
Yeah blow dryer. Also because the spider webbing is such fine lines it will take some time to remove the transfer tape from the design. I suggest peeling at an angle with your scrapper tool in one hand to help push any vinyl back on to the glass. Good luck and may patience be with you.
Thank you. I’ll try this. I just need to buy a blow dryer :sweat_smile:
What worked eventually?
Pressing down really hard plus lots of patience​:sweat_smile: I don’t have a blow dryer :sweat_smile:
I think @Marino meant that you’re already trying the wet method unintentionally
Do you have a brayer?
Yes I do :smiling_face_with_three_hearts: I have a big one and a tiny one that I bought by accident because I didn’t read the description and I wasn’t expecting it to be that tiny :rofl::sweat_smile:
Maybe I need to try the wetter method because the vinyl simply wasn’t adherin to the moist but not so wet glass :sweat_smile:
That’s exactly the kind of thing I would do! :rofl:
