Anti-gaspy
Could we place librairy’stickers and images from internet in the same page ?
I saw the cutting was different depending on the source.
Thanks a lot for your share.
You can place an image from the library and upload your own images to the same canvas. Just pick the operation for each image. For instance do you want to print then cut or do you want it to be a standard cut
You can place both and select the function you want to do > standard cut, print and cut, draw, foil, score :smiling_face_with_three_hearts: just need to select the proper layers and operations
