Hello!
If we create our own boxes in the app, respecting the dotted and solid lines, do you think it will cut them like the ones offered in the library? Have you tried it yet?
The dotted lines are intended for scoring
Mine is the Crafter, and its software doesn’t support scoring or perforation yet. However, I’ve managed to do perforated cuts with it using designs made in Illustrator — simply by converting a dashed line into a path. So I guess with the iCraft, you should be able to do it too, by replicating the lines used in the IdeaStudio templates.
