Hi! I’m interested in learning about your experience with the Loklik when cutting various paper thicknesses. Specifically, how does it perform with thicker materials, such as 400 or 590 gsm cards used for VIP Membership Card packaging? What factors should be considered when using the Loklik Crafter for these types of cuts?
I think you need the deep point blade to try to cut that thick
If it can cut balsa wood, I’m pretty sure it can cut thick card. I’m Presuming it will need a deep point blade or a knife blade that’s if they have one but that’s my best bet.
In my country, there are no available Loklik parts. Would Cricut blades work with Loklik?
I have both machines but unfortunately I don’t have a deep point blade for cricut I only have it for the Loklik so I can’t compare ![]()
Loklik crafter can cut up to 1mm and the iCraft can cut up to 2mm based on their descriptions. If the materials you’re planning to cut falls in these thicknesses then maybe the Loklik cutter can cut them. But you’ll need a 60° or deep point blade for these
