Cutting Sintra Board
Has anyone tried cutting sintra board using Loklik icraft?
No sorry. You would have to just keep in mind the thickness restrictions of the material you are cutting. Also I would probably use the deep point blade.
Thank you for the suggestion! I was actually thinking of using it for cutting some of my projects. I’m struggling a bit with cutting sintra board, so I’ll make sure to keep the material thickness restrictions in mind and try out the deep point blade as well. I really appreciate the advice!
You will probably need multiple passes as well. Can be as many or more than 15 passes. It may take a bit longer than you expect. Before unloading the mat you can check your cut and then restart the cut if it hasn’t cut through as well.
what thickness of sintra board? I carft can cut up to 2mm already tried 1mm rrefmagnet with photosticker and phototop aplied on
3mm lite sintra board
Hello! Cutting machines are not meant to cut sintra boards though some crafters have already tried ut but this may result frequent blade replacements or worst break your machine😅
Thanks for letting me know! I just wanted to double-check before going ahead with it.
I think brother was tested for sintra board but not only up to 2 or 3mm I think. iCraft can only cut up to 2mm but I think the rollers might cause ridges on the sintra board
Maybe a cnc machine waoooah deabak🤣
Di na naubusan ng machine :rofl: ubos na space pero daming need na machine :rofl:
Hope Icraft can do it tooo
I Hope Too
