For today’s Daily Mission Challenge, we are diving into one of the most exciting holiday season topics of all. If you are planning to pick up a LOKLiK iEngrave Laser, this mission is all about preparing yourself with the tools, materials, and helpful add ons that will make your experience smoother, safer, and far more enjoyable.
One of the biggest advantages of choosing the LOKLiK iEngrave Laser is that LOKLiK and HTVRONT offer an entire range of accessories designed specifically for laser crafters. Their store is packed with materials that are already tested and safe for diode lasers. This means you can spend less time guessing what will work and more time crafting. You can find a wide variety of blanks that include wood sheets, acrylic, faux leather and coated materials that respond beautifully to engraving or cutting. Having materials that are consistently reliable makes learning your laser so much easier.
For wood projects, I personally prefer using prefinished wood. Prefinished sheets give you a smooth surface that engraves cleanly and consistently. They also reduce the amount of sanding and sealing you need to do which saves time for larger projects. They come in several species and color tones which makes them versatile for ornaments, signs, layered projects and mixed media designs. If you have never used prefinished wood before, it is worth trying because of how crisp your engravings will look.
There are several tools that can make your laser workflow much more efficient. A good set of calipers is extremely useful because it allows you to measure the exact thickness of your material. Accurate measuring helps ensure your settings are correct and keeps your cuts clean. You may also want to have a dedicated soft bristle brush nearby for cleaning your engraved surfaces without scratching them. Adhesive hooks or clips can help you organize your cord management and keep your workspace clear. Keeping a small notebook or digital document for logging your settings will save you a tremendous amount of time once you begin experimenting with different materials.
Here are a few optional additions that can also be very helpful
• A small air blower or air assist attachment to reduce scorching on wood and improve cutting performance
• Masking tape or painter tape to protect surfaces when you are engraving pieces that need a cleaner finish
• A compact vacuum or gentle handheld air duster for loose soot and debris
Your mission today is to think about how you want to set up your laser space and what tools would help you work more comfortably and efficiently. Take a look at the materials offered in the LOKLiK and HTVRONT store and start exploring which blanks inspire you. Imagine the types of wood you want to try and the projects you are most excited to begin. A well prepared craft room always leads to more creativity and fewer frustrations.
If you are getting a laser this season, today is the perfect day to plan ahead so that you can jump into your new creative adventure with confidence.
