Daily Mission: Decoding File Formats — SVG vs PNG and Beyond
One of the things that I found very confusing when I first started using my vinyl cutting machine, starting to sublimate, and cutting materials with my laser was… which file is which.
So, let’s talk about something that’s a bit less flashy but incredibly important when it comes to crafting: file formats!
As crafters, we all know that having the right file for the right tool makes all the difference — whether you’re sublimating with your HTVRONT Auto Heat Press, engraving with LOKLiK, or designing a custom vinyl decal. But with all the different file types out there, it can get confusing. So, let’s break down a few common formats and what they’re best for!
SVG (Scalable Vector Graphics)
This is the gold standard for crafters! SVG files are perfect for cutting machines (like LOKLiK’s Crafter and iCraft, Cricut, or Silhouette), laser engravers, and heat presses because they’re vector-based, meaning they can be scaled to any size without losing quality. If you’re working with intricate designs or need crisp lines for precise cuts or engraving, SVG is the way to go.
PNG (Portable Network Graphics)
PNG files are ideal for digital designs, especially when you need a transparent background. They’re great for sublimation printing on HTVRONT products, as they hold the color details well, but the downside is they’re rasterimages, meaning they don’t scale well. If you need something for a digital mockup, or a simple one-color design on a tumbler, PNGs are often your best bet.
JPG (JPEG)
JPEGs are usually used for photos and high-quality images. However, like PNGs, they’re raster-based, so they lose quality when resized. Not ideal for cutting or engraving, but great for sublimation or printing where the resolution won’t change.
DXF (Drawing Exchange Format)
This one is mostly used with laser engravers and cutting machines. If you’re looking to get precise cuts for things like wood or acrylic, DXF files are often recommended. Like SVGs, they’re vector-based, so you won’t lose quality when resizing.
Quick Tips:
  • Use SVG for precise cuts and laser engraving — it ensures clean lines and scalability.
  • Opt for PNG if you’re working with sublimation or creating digital files with transparent backgrounds.
  • JPEG is best for photos or large images that don’t require resizing.
So, next time you’re working on a project, make sure you’ve got the right file for the job! What file formats do you use most often in your crafting? Do you have a favorite, or have you ever struggled with the wrong one? Let’s share tips and experiences to make those projects a little easier.
PNG was originally the native format of Macromedia Fireworks, the Photoshop of Macromedia before Adobe gobbled it. It is a pity as the original format had two versions:
  • Vectorial and editable (it was a project extension). Fireworks had wonderful tools to make animated gif from them.
  • The regular raster png we know today. This format, unlike jpg, supports alpha channel, so transparency. It also keep the original image depth without compression, unlike jpg, thats compress the image with the following quality loss. That’s why it was originally used when quality transparency was needed, instead of gif, and now it is used, even without transparency, when quality was needed. So I recommend using png in those cases and jpg when you need quick screen charge and low weight.
OMG! I’ve seen all those formats being born and some die. This is format historiograhy :joy: Fireworks was a great program, Adobe should have kept it.
Oh, and for Loklik’s Crafter and iCraft too :stuck_out_tongue_closed_eyes:
I was actually editing the post as you wrote that to include the LOKLiK machines as well. I often cut and paste when I am doing larger posts and realized I had left it out. LOL!
Ahh that’s what the DXF files re that came with some things I just used the svg file for laser engraving :joy:
I was in the same boat when I started downloading files. I was like… what’s this and more importantly why can’t I use it? LOL! You tell me I can’t and I will figure out why not. HA!
Which file type is best for print then cut?
That is a great question. PNG’s are by far the best and most commonly used file type for Print then Cut features.
Here’s why PNG is ideal:
  1. Supports Transparent Backgrounds
  • This is key — it allows your cutting machine to cut exactly around your design rather than a square or rectangle border.
  • Example: A PNG of a pumpkin will only cut the pumpkin outline, not a white box around it.
  1. High Image Quality
  • PNGs use lossless compression, meaning your printed design stays crisp and vivid — especially important for detailed or photo-based prints.
  1. Easy to Resize
  • PNGs scale well without distorting edges or colors.
  1. Compatible with Design Software
  • Works seamlessly with design spaces, studio software, other design tools.
Awesome! Thanks so much for the information. :heart:
Absolutely @Samantha_Bryant! May come in handy as you test that new heat press! :grinning:
Oh, yes, it just may. :blush:
