Iām curious what sticker paper is best?
Can you recommend a pack and if you laminate your stickers, what kind of laminate do you use?
Thank you!!![]()
Thank you!!![]()
I have used the htvront printable vinyl and have used their clear laminate sheets. It also comes in a roll. I also have holographic design laminate sheets as well that I use sometimes too. The clear ones can be a bit tricky ink does not always sit on them right it depends on printer.
