This design was born from a place of deep gratitude and joy. I wanted to create something simple yet powerful—something that speaks to the miracle of new life and the prayers that often precede it. “ANSWERED prayer” is a gentle declaration of hope fulfilled, perfect for faith-filled families and meaningful gifting.
Materials Used:
- White baby onesie (Gerber brand)
- Printable transfer paper
- Epson EcoTank 2850 printer
- HTVRONT H10 12x10 heat press
- Scissors
- Design software: Canva (for layout) + IbisPaint X (for mirroring)
Process & Tips:
I designed the text in Canva, mirrored it in IbisPaint X, and printed it using my EcoTank printer. After trimming the design, I placed it face down and pressed it with my HTVRONT H10 heat press.
Here’s what I learned: the transfer paper I used specifically advised against using an easy press. It recommended a swing arm heat press or a home iron instead. Because I didn’t catch that detail beforehand, the design didn’t fully adhere and showed some cracking. That wasn’t the H10’s fault—it was a user oversight. I’ve had great results with this paper using my professional swing arm press before, so I’ll be re-trying it that way for a cleaner finish.
Creative Insight: Always double-check your material instructions before pressing, especially with printable transfers. And even if the result isn’t perfect, the message still shines through.
