What’s Father’s Day without a Happy Father’s Day card. This card was made by elements from the library in Idea Studio. This makes a 12.5 cm (5inch) by 17.5cm (7inch) landscape card. You can use the score line within the project or you can score manually at 12.5cm for the card base. To make it easier cut I did change the colour of the base card to grey within the program to cut, if you don’t you will end up cutting the front panel of the card as well as the base of the card at the same time. I also used the draw function to write the sentiment within the card.
Very nice card ![]()
Thanks so much for sharing this! the note about changing the base card colour to avoid cutting both layers at once is super helpful for anyone new😊
Thank you, I’m so glad you like it
Yes, I have been caught out by that mistake a couple times now lol. Thank you for your kind words
beautiful card you did a magnificent job
Oh, thank you so much. ![]()
