I made this Mother’s Day card using LOKLiK Idea Studio Library elements. I customized each element to suit my needs. I really like this colour combo, I think they really complement each other. I used my LOKLiK iCraft to cut out all the pieces and also write my sentiment inside my card. This project would work with the iCraft or Crafter
Materials used
Card Stock for Card Base - 210GSM
Card Stock for the rest - 180 GSM
LOKLiK iCraft / Crafter
LOKLiK Idea Studio Library for designs
Glue
Scrapper
Brayer
Tweezers
Light Grip Mat
Step 1
Write your sentiment
Step 2
Select all the layers and press make. Be careful if you have the same coloured layer on top of each other as the machine will cut them all out at once. You can arrange the layers around your mat to cut. Just make sure you line up your paper on your cutting mat to where LOKLiK Idea Studio says it is on the screen.
Step 3
When cutting the base of your card, you will need to use the large cutting mat 24inch by 12inch. As it’s to big to fit on the normal mat. If you want to cut this out seperately not on your machine if you don’t have the larger mat the dimensions are 12.5cm W x 35cm H and you want to score at 17.5cm
Step 4
Glue all your pieces together.
