Where do you get your sticker images from when you don’t have your own or can’t draw for nuts?
Answer: Easy, use the built-in Library images!
This entire sticker sheet was made using only graphics found right inside the LLiS image Library. No uploads needed! You can even ungroup the designs to use just parts of each element. No drawing skills required, just search, size, Print then Cut!
While this isn’t a beginner project, it’s a great example of what’s possible using only the tools provided in the LLiS Library, and using your editing canvas tools.
Best demonstrated by video for a full step-by-step view!
The library needs improvements, but no doubt that’s a great thing to have there. Even when creating your own designs, you never know where the inspiration ignites.
