I was setting up my DTF printer and it was going well. I almost had the heads all clear and printing correctly. I reset it and now it goes all the way to the left and gets stuck, while making a horrible noise. Help me before I cry or throw it!
Hi and welcome to the community @amber_acevedo! I’m sorry you run to this situation. Here are some Guidelines for your reference only.
What’s Likely Causing the Grinding & Stuck Head
1. Capping Station Misalignment
- If the capping station gears or height are off, the printhead can crash into it during startup.
- This is a common cause of loud grinding and the head slamming left.
2. Dirty or Misread Encoder Strip
- The clear strip behind the carriage tells the printer where the head is.
- If it’s dirty or misaligned, the printer “loses track” and slams the head to one side.
3. Firmware Reset Confusion
- A reset can sometimes scramble the printer’s idea of its home position, especially if done mid-clean or mid-calibration.
Step-by-Step Rescue Plan for HTVRONT DTF
Step 1: Power Off Immediately
- Don’t let it keep grinding—it can damage the motor or belt.
Step 2: Manually Move the Printhead
- With the printer off, gently slide the printhead away from the left.
- Check for obstructions, ink puddles, or broken plastic near the capping station.
Step 3: Clean the Encoder Strip
- Use a lint-free cloth and isopropyl alcohol.
- Gently wipe the clear strip behind the carriage—this helps the printer “see” positioning again.
Step 4: Check Capping Station Alignment
- Look underneath: the white lock gear and rubber wiper should alternate positions.
- If they’re out of sync, use a flathead screwdriver to gently rotate the gears until they align properly.
Step 5: Verify Capping Station Height
- Move the printhead manually across the rail.
- If it catches or grinds near the capping station, it may be too high—adjust it slightly lower.
Step 6: Restart and Watch
- Power on and listen carefully.
- If it still slams left, try disabling auto-clean in the software and manually resetting the carriage position.
HTVRONT Cleaning Guide: How to Clean DTF Printer Head – HTVRONT
Hope it helps! Please keep us updated!
I’m sure that complete guidance is going to help, you’re so kind.
Thank you! I got it fixed!
Yayyy so happy you got it running right today! I’ve been saving for this machine and following everything on here and YouTube to learn all I can
I am still trying to be able to use the machine. I am so close! I can only get the images to print yellow and white. What am I doing wrong? I have cleaned, there is ink, etc…
Hey @amber_acevedo! You’re so close—hang in there!
It sounds like your machine is trying to cooperate, but something’s off with the color output. If you’re only getting yellow and white, here are a few things to check that might help unlock the rest of your colors:
Quick Troubleshooting Steps
Run a Nozzle Check: This will show which colors are actually printing. If cyan, magenta, or black are missing, it could point to a clog or ink flow issue.
Deep Cleaning Cycle: Even if you’ve cleaned already, running a deep clean (especially for the CMYK channels) can help clear stubborn blockages.
Check Ink Cartridges:
- Make sure all cartridges are properly seated.
- Look for air bubbles in the lines or vents that might be blocked.
- Software Settings:
- Double-check your print settings—sometimes the color profile or media type can affect which inks are used.
- If you’re using RIP software, make sure the channels are mapped correctly.
Bonus Tip
If your machine has a test print or purge file option, try printing that—it can help force all colors through and show what’s working.
You’re clearly doing all the right things, and it’s just a matter of narrowing down the last piece. Let us know what you’ve tried so far and we’ll keep troubleshooting with you! ![]()
I am having issues with my sublimation printer. Instead printing purple the color came blue .
Oh no, that’s frustrating!
If your sublimation printer is printing blue instead of purple, it could be a color profile issue or something off with the ink balance. A few things to check:
Make sure your design software is using the correct ICC color profile for your printer. -
Run a nozzle check and head cleaning—sometimes clogged magenta nozzles can cause purple to shift toward blue. -
Double-check your ink levels, especially magenta and yellow. -
Try printing a test image with known colors (print purge) to see if the issue is consistent across designs.
Thank you.
