Come join me while I create this beautiful colourful easter egg hunt tote bag ![]()
As I received my Loklik Impress Auto 2 last week,
I wanted to do a project using it
So let’s see what we need to make this project
Materials
Laptop / Tablet / mobile
Idea studio
Loklik Icraft / crafter
Heat press
Colourful Htv
Sticky mat
Weeding tools
Heat resistant tape
Teflon sheet
Tote bag
Open your Idea studio and let’s get started
Search for Easter and choose the designs, I already have them saved in my favourites
And to add a cross just search for it too.
From the shape menu I chose a square to be my template area
I’ve sent it to the back and started adjusting my design
From the colour menu I chose the colour picker tool to change some of the colours as I wish
I wanted the base colour to be one piece (as it was 3)
So I duplicated the egg and took one and welded it all together.
The other egg I ungrouped it, deleted the blue parts, grouped the small parts together and put them over the solid coloured egg.
I wanted to make two more eggs for that design in different colours, so I duplicated it and changed the colours as I wish.
Now that the design has a lines of dots we need to unite every line together to make it cut in the right sizes.
After that I sorted every group of shapes with same colour together and grouped them.
I sorted the colours separately on the Canvas and matched them on the mat.
All should be at the same place which is a little bit tricky but you can do it.
Now let’s come to the Cut settings
I chose
Of course don’t forget to mirror
Turn your lovely machine on and start the magic
After we cut all the parts needed successfully the Weeding will be very easy
We need our scissors from time to time and today it is needed to separate the shapes of the same colours
Turn on your Heat press and set the materials
I chose
Pre press the Tote bag for 5 seconds to remove the moisture and wrinkles.
Then I started placing the htv where I want it to be
(you may need to use heat resistant tape)
Cover the design with Teflon sheet
Now we press and as the Impress Auto 2 has a safety mode I need to make it start pressing by using my two hands.
After the time is finished peel off the transfer tape.
Now I started layering all the small cute parts and repeated the pressing process.
For the cross I was using Metallic htv and it should be left to the end coz too much heat will make it wrinkle.
Now that we have finished turn off the heat press and enjoy your beautiful creation
If you have any question please write in the comments and I’ll be happy to help you.
Your creator Marin from marinos.creations
