I selected an image from the program but no matter what image I choose I keep getting this error. Help please
Hello Lisa! I’m sorry you need to explain a bit. Is “Image has no vector lines” is the error you get? when do you get it? The image from the program is from the Library, or uploaded by you to the canvas? anyways, is it a vector image?
Do you have the image selected when you go to press make? You can check if your image is selected by seeing the blue box around it or in the layers panel seeing that it is highlighted.
Yes it seems there,s nothing selected, no that you say. I think that,s the message you ge5 when you go Make with nothing selected. Remember you can choose what to make by selecting only some layers, so the software doesn,t make what,s no canvas but what you select.
You have yo click Standard cut or Print and cut job tohave vector line
Click on the image then choose design so you can choose from standard cut or print and cut
