We have a drawing in svg format. I don’t want to cut the inner lines of this drawing. I only want it to cut the outer lines. How can I do this?
I tried with offset but it didn’t work. Either I made a mistake somewhere, or I’m trying the wrong method.
Can anyone help?
Try changing the color of the contours then simply select the color you want to cut
Like this one, if you only want the outer part to be cut, choose black in the layers, don’t click on the white one
Hope that helps with your concern
I think what you’re looking for? Is a can’t to feature. I’m unsure at the moment if that’s available on the LOKLiK studio. Maybe somebody else that’s more familiar with the program can help
