Foil transfer
I am trying the loklik foil transfer kit. However currently I can only do the outer line of the letters, is there also away to foil the inner part of the letters? So the have filled letters?
i think that is impossible you can only do the line the same is for the pen if U use that to write in loklik
Thank you, I also have another issue: I can wipe out my foil - is there a solution this?
Maybe a workaround would be to have several layers of insets?
how would you do this?
By using the offset feature. You would decrease the size rather than increasing it for the offset.
