Can someone create an image I have. I want to delete the black background. Im new and wasting alot of vinyl
On my end I don’t see any black background. The output size would also have an effect on the cut. If your cutting a small sized image, your machine might have a hard time cutting it. Might be better off having it outsourced as DTF or UB DTF print
You want that exact image. I also don’t see a background. How big is this image going to be.? Do u want to remove the gold and just have the outline
If you just want to cut the yellow, you could just select the yellow layer in Idea Studio and cut that. I’m not sure what black background you are seeing, do you mean the black outline?
