Help Us Help You: How to Ask Better Crafting Questions and Get Accurate Answers
One of the most common questions across crafting communities is some version of:
“I have a t-shirt. What time, temperature, and pressure should I use?”
It’s a great question—but it’s incomplete.
As someone who has been crafting for decades and works hands-on with presses like the HTVRONT Auto 2 Heat Press, the H17 Phone Case Heat Press, and the A200H Tumbler Heat Press, I’ve learned that heat settings are never one-size-fits-all. The more detailed your question is, the better and more accurate the answers you’ll receive. Let’s talk about what information you should always include when asking for help.
1. Tell Us About the Blank
Not all t-shirts are created equal. The blank itself dramatically impacts your settings.
Be specific about:
  • Fabric content (100% cotton, 100% polyester, 50/50 blend, tri-blend, etc.)
  • Fabric weight (lightweight fashion tee vs heavyweight cotton)
  • Brand (e.g., Gildan Softstyle vs Bella + Canvas)
  • Color (especially important for sublimation and dye migration issues)
  • Any special coating (poly-coated blanks for sublimation)
Why this matters:
  • Sublimation only works on high-polyester, light-colored garments.
  • Cotton absorbs moisture differently than polyester.
  • Heavyweight fabrics require different pressure and heat distribution than thin fashion tees.
  • Some blends scorch easily at higher temperatures.
If you simply say “I have a shirt,” we cannot accurately guide you.
2. Tell Us What Machine You’re Using
Heat presses vary significantly. Settings that work on one machine may not transfer directly to another.
Be clear about:
  • Brand and model of heat press (clamshell, swing-away, auto press, mini press)
  • Whether it is manual or auto-pressure
  • If you are using a home iron (yes, that matters)
  • If your machine has adjustable pressure or preset pressure levels
For example, an auto-adjusting press behaves differently than a manual clamshell where you control the pressure strength yourself. Temperature consistency and platen size also affect results.
Without knowing your machine, recommendations are just educated guesses.
3. Tell Us What Transfer Type You’re Using
This is one of the biggest missing pieces.
Are you using:
  • Sublimation
  • HTV (Heat Transfer Vinyl)
  • Iron-on (pre-made transfers)
  • DTF (Direct to Film)
  • Screen print transfers
  • Puff vinyl
  • Glitter vinyl
  • Specialty vinyl
Each material has its own manufacturer-recommended settings. Even within HTV, glitter vinyl requires different settings than everyday vinyl. Puff vinyl expands under heat. DTF requires firm pressure and a cold or warm peel depending on the film. Sublimation needs high heat and longer press times compared to most vinyl.
If you only say “I’m pressing a design,” we don’t know what material rules apply.
4. Share the Manufacturer’s Recommended Settings
Before asking the community, check the packaging or website for recommended settings.
When you post your question, include:
  • The recommended time
  • The recommended temperature
  • The recommended pressure level
  • Whether it calls for cold peel, warm peel, or hot peel
Then explain what happened when you followed those instructions. Did it scorch? Not adhere? Peel up? Look faded?
This gives others a starting point to troubleshoot intelligently instead of guessing.
5. Describe the Problem Clearly
If something went wrong, describe it in detail:
  • Did the vinyl lift at the edges?
  • Did the sublimation look faded or blurry?
  • Did the shirt scorch?
  • Is there dye migration?
  • Did it peel after washing?
Also include:
  • How long you pressed
  • If you pre-pressed the shirt
  • If you used butcher paper or a cover sheet
  • If you adjusted pressure
Troubleshooting requires context. The more details you provide, the faster someone can pinpoint the issue.
Best Practices to Remember
1. Always Pre-Press
Pre-press your garment for 5–10 seconds to remove moisture and wrinkles. Moisture can interfere with adhesion and sublimation bonding.
2. Use a Heat Gun to Check Temperature Accuracy
Not all presses heat evenly. Testing your platen can reveal hot or cool spots.
3. Pressure Is Just as Important as Temperature
Many crafters focus only on time and temperature. Pressure is equally critical. Light, medium, and firm pressure produce different outcomes.
4. Know Your Fabric Limits
Polyester can scorch or melt at high temperatures. Cotton can scorch at prolonged heat exposure. Always test on a scrap or inside hem when possible.
5. Do a Test Press
Before committing to a bulk order or customer item, test your settings on the same material.
6. Keep a Craft Journal
Write down:
  • Blank type
  • Transfer type
  • Settings used
  • Results
Over time, this becomes your personalized heat guide based on your specific equipment.
The Bottom Line
When you ask a question like:
“What time, temperature, and pressure do I use?”
You’re missing the most important variables.
Instead, try:
“I’m using a 100% cotton Gildan Heavy Cotton shirt with HTV from Brand X on a clamshell press. The manufacturer recommends 305°F for 15 seconds at medium pressure. I pressed at those settings and the vinyl is lifting at the corners after cooling. What adjustments should I try?”
Now that is a question the community can confidently answer.
The more information you provide, the more accurate, helpful, and fast your responses will be. Crafting is both art and science. If we share complete information, we elevate the entire community and help everyone succeed.
Let’s all commit to asking better questions so we can all get better results.
Totally agree. I’ve had a few questions, lately, that have had no context, and I’m just like, I don’t know how to help you, if I don’t know what the actual problem is. :laughing: I want to help, but I must have more information. Thanks for posting this. :smiley::+1::heart:
Great advice Cory. Heat pressing is never a one-size-fits-all.
Oops. Wrong place.
What a beautiful and meaningful idea @kimberlyrudy! Your kitchen wall sounds like such a special place filled with memories and love. I absolutely love how you used different colors to represent the people in your life — it turns the wall into a living family tree in such a creative way. Having your granddaughter’s handprint from when she was only two weeks old must be incredibly special. Those tiny prints are something you can never recreate later, and it’s amazing that you captured that moment in such a lasting way.
Projects like this are what crafting is really all about — preserving memories and celebrating the people who mean the most to us. I can only imagine how wonderful it must feel to look at that wall every day and see the story of your family and friendships growing over time. Thank you for sharing such a heartfelt project with the community!
Here is their family. Every print has the date it was done.
I’m so sorry. I posted this at the wrong place.
That’s fantastic. Such a great idea and it looks so beautiful with all the colours. :clap:
3 posts were merged into an existing topic: :gift: VOTE | What Should Be Next for the Europe Store?
