How to cut Felt sheet
Hello, has anyone ever cut felt sheet with icraft? I used a pink and purple lining, but it doesn’t work, everything is always stuffed. thank you.
Which blade did you use?
I first used it for thicker materials, but the cuts were very noticeable in the board, and it cut badly. then I tried for thin materials and it was torn.
Maybe you need new or cleaner blades to cut the felt fabric. Play around with speed and force to check which settings work best
