#DailyMission2 It’s here! It’s finally here! I have the HTVRONT A200 Auto Tumbler Press. Now, how do I sublimate on a 40oz tumbler? What are the measurements for the three areas?
If you open Loklik Ideastudio and search under machines for the A200 there are already templates for the 40oz tumbler fitted for the HTVRONT ones and probably fitting most of the others.
Just measure if they are similar.
Then just place your design over the templates and use the clip mask tool and it will size it according to the templates.
Hope this helps you out.
Hello!
Question why the clipping mask tool might be grey out? I can’t use it ![]()
On the official HTVRont Youtube channel are some detailed videos on how to use it. Maybe this helps.
In my region the A200 isn’t available yet so I only can recommend you watch these tutorials.
I only use the desktop version of LLIS on my laptop not the mobile app maybe this might be issue since there are some features that are at the moment only available on either the mobile app or the desktop version.
I was using Loklik desktop version. I’ll check YouTube and see if there is anything there that can help me figure out the issue.
