There was no RED LINE in the previous versions of the software. It now makes it very limiting. I hope this can be removed so we can maximize the materials ![]()
Yes I’ve posted about that earlier and showed the big gap that’s almost 1 cm from the corner and I’m hoping it will be fixed with the new update
Same! I cannot use my phone in cutting because of the red line which is not accepting the image to proceed in cutting.
You’ll have to resize it to be inside that red line. But that is frustrating so I hope they remove it since that wasn’t there in the previous versions ![]()
I hope they can notice our requests for the better of the software
Thanks for your feedback! To enhance cutting stability and ensure more precise, consistent results, we’ve introduced the red border in the software. This adjustment applies universally and is designed to provide a smoother cutting experience for all users.
We understand this may affect your workflow. Really appreciate your input, and our tech team are always working on optimizing the software to improve your experience ![]()
We understand that but the line can be put a little to the edges so we could still have at least 29 cm space of cutting. I this a whole cm from the edge is too much. I don’t like wasting vinyl ![]()
Me too. It saddens me to waste material especially when they’re quite expensive nowadays. ![]()
I’m guessing this was the solution for the cuts above the grid space of the mat? However too much material is wasted with that big outline border
I hope there can be another solution ![]()
I do hope this can be fixed. We like to make most with our materials ![]()
Is this the same same for print and cut?
Yes, when you go to MAKE it’s there ![]()
