IdeaStudio 2.4.0 | We heard you — here’s what’s new 👇
Your images need to be “clean” and not too pixelated I guess for it to be more precise
My lines aren’t pixelated. What I meant was the LOKLiK import process now increases the width of the lines and I need them to be exactly the width i created them, which was how it was before the ‘update’
Let’s call the attention of the @admins so they can relay your concern to the tech team :smiling_face_with_three_hearts:
Ooooh how exciting , no more paper wastage yaaay
I dunno if this is the whislist place… xd but.
Please add a snap-to-0,0 feature. I import an A4 layer to use as a reference, and I have to manually position it using the X and Y fields because it places the design in 25.4 XY by default.
Editing the Size and Position values through their text areas is quite uncomfortable when selecting them by click-dragging from left to right, as it scrolls the toolbar. So I usually end up using Ctrl + A to select all in order to position my design at 0,0. This doesn’t happen in the Rotate field, though — I’m guessing it’s because the W/H and X/Y fields are inside the scrollable area, while Rotate isn’t.
EDIT: Rotate also scroll the toolbar. The scroll is not comfortable nor common in design applications.
I agree with these suggestions :smiling_face_with_three_hearts:
