I hope it helps ![]()
This update is cute, but this should go beyond the print calibration. The print page doesn’t fully print on my HP inkjet printer.
And then when I desire to make stickers that have the white outline, I have to wait a LONG time for the Desktop app to expand the border so it won’t cut into the image. And even then, with calibration, it still doesn’t perform the kiss-cut properly. So maybe it’s just my machine or something because now it’s collecting dust.
Also, we need proper and REAL layering if you’re going to offer it especially when it comes to graphic designing or uploading premade images.
Which machine do you have? Have you selected the correct paper size you are using? Also are you printing at 100%
I hope someday more Materials Cutting Settings will be added like for vellum paper or photo paper. thank you!
Which machine version do you have? The iCraft or the crafter?
Make sure correct paper size is chosen and print output is not scaled, it should be 100%
The cutting parameters are simply suggestions, you can adjust them accordingly to you liking since not all brands create the same exact materials. It’s always best to do a test cut 1st.
On the iCraft, you can also create your own cut settings for your materials
You can make your own cut settings for the iCraft to customize them and label them for future reference
Are you referring to my printer? Of course I always print at 100%. It’s a setting that has to deal more with my printer than the cutting machine.
The issue is with the cutting machine as I stated - the calibration isn’t correct when doing kiss-cut stickers. Since this is a Loklik iCraft 2, then I shouldn’t have an issue with calibration, print-then-cut, etc. but I do. I know what my paper settings are since I’m using HTVRont adhesive vinyl, heat transfer vinyl, and transparent sticker sheets.
