Hi Community!
This update is all about making your creative process smoother, from larger file uploads (a highly requested one lol) to project module upgrades, from more precise engraving to improved cutting machine calibration.
Here’s what’s new ![]()
IdeaStudio Desktop
Larger File Uploads & Saves
You can now upload and save files up to around 10 MB, perfect for bigger or more complex projects.
Project Management Improvements
You can now rename projects anytime, open multiple projects at once, and overwrite ones with the same name.
New Creative Tools
Added a Warp effect with 30 templates, available for both text and vector graphics.
Upgraded the sketch algorithm for cleaner outlines and no more double strokes.
Laser Engraving Optimization
- Added Wi-Fi and IP connection options (requires firmware V2.0.15 or above).
- Added an Air Pump function to prevent material scorching.
- Added Overscanning for sharper corners and more precise engraving.
Cutting Machine 2 Calibration Upgrade
Now supports material-based calibration. Your calibration settings will be saved and automatically matched next time, helping reduce material waste from repeated calibration.
LOKLiK App
Added Air Pump and Overscanning functions for cleaner, sharper engraving results.
You can now calibrate based on different materials and save each set of parameters for quicker use.
New Auto Tumbler Heat Press Positioning
Added a visual guide for the heat press area, making it easier to locate and align your design accurately.
New Mask Feature
Combine images and text more freely for flexible, creative designs.
Other Improvements
- Upload limit raised to around 10 MB.
- Projects can now be renamed and overwritten when saving.
- Upgraded sketch tool for smoother outlines.
Coming Soon (IdeaStudio Desktop & LOKLiK App)
- More shape options in the Shape tool
- Improved Printable Calibration flow
- Enhanced Printable Cutting Marks (maybe another highly requested one lol)
- Optimized Material Management
Since shape optimization is already on the way, we’d love your input!
Tell us what shapes you’d like to see added next in the Shapes tool.
We’re keeping an eye on your feedback, and some of your favorites might just make it into future updates.
