Imprimir y cortar
Saludo, he visto muchos comentarios sobre el imprimir y cortar de la maquina que lo hace muy malo y por mas que las calibre sigue haciendo lo mismo. Entonces diganme que solución le han dado a eso porque la voy a usar mucho para hacer topper y se usa mucho el imprimir y cortar.
Which machine do you have? If you have the crafter the process of calibrating was a bit hard and tedious. If you have the new icraft machine the calibration process is alot easier. My tips are to make sure you have updated your software and firmware to the latest versions. Then calibrate the print then cut. Test out your cut. Mine cut pretty well on my first calibration. I have the calibration process for print then cut so you can see.
Highly recomemded this videos :smiling_face_with_three_hearts:
Oh thank you for your kind words
Which machine are you using? The 1st version - loklik crafter or the newer 2nd version - loklik iCraft? From there ypu can look for tips and trick on how to use it
