Infusible Ink Sheets
Does anyone know the cutting settings for Infusible Ink Sheets. There is no preset for them. Also the best way to weed them. First sheet was an absolute disaster! Thanks
I haven’t tried infusible sheets yes. Are they thin or thick material?
Hello! You can add your own materials and settings in IdeaStudio. Maybe you can do a test cut first?
Yes, that’s the best idea, test a range of forces on the bottom corner of the sheet, out of your design area, or start with a regular setting and see what happens even without unloading the mat. Use that option even when you finally cut your design, so that if it needs more cutting you can perform a second or any number of passes.
And please, don’t forget to letbus know.
I’ve cut mine on the regular HTV setting, its worked several times but I also find that brand matters. Surprisingly the Cricut infusible ink sheets have been the best for me.
welcome to the community Tania @Blossom12370 :star_struck:
