💡 Insight Hub #19 | Beyond Today’s Heat Press, What Would You Create?
Hello everyone :wave: Welcome to a new edition of Insight Hub!
Lately, we’ve been asking ourselves one simple but important question, and we’d really love to hear from those of you who work hands-on every day:
:point_right: If heat press machines were not limited to today’s forms, sizes, or use cases, what would you truly want to create?
Not just shirts, hats, or tumblers, we’re especially curious about ideas beyond what heat press is commonly used for today.
This is a space to freely share your ideas and experiences. Your real-world insights help us better understand what creators actually want to make next.
We’re especially curious about things like :point_down:
:small_blue_diamond: What new products or categories would you love to make or sell using heat press?
(Even if it feels unconventional, niche, or not possible yet)
:small_blue_diamond: Are there any moments where you thought:
“Heat press could be used here… but current machines just don’t allow it”?
:small_blue_diamond: In your current workflow, which steps feel like barriers rather than creative work?
(Too manual, risky, repetitive, or time-consuming)
:small_blue_diamond: Beyond existing heat presses, what kinds of machines, materials, or new capabilities do you wish existed? (Safer? Faster? More automated? Compatible with more materials?)
:speech_balloon: All ideas are welcome, share whatever you think!
:bulb: How to Join
Simply share your thoughts in the comments below.
:gift: Small Reward
We’ll randomly pick 3 participants from the comments to receive 20 Community Cheers each as a thank-you for joining!
Thanks for sharing! Every insight counts, every idea builds the future. :dizzy:
This is a very interesting topic. I think being that the majority of people have very limited space in our homes its the fact that we need so many heat presses to work on various jobs. For instance I have my Auto heat press but then I added tumblers so I got the auto heat press. Of course for small jobs I need my mini heat press. The theres the phone case press which if ypu want full professional coverage is a must have. However once you decide to add hats for efficiency you cant beat the hat press. It goes on and on. So for me I need the machines to be versatile and as many as possible to be combined into one slim lined multifunctional machine.
When you look at having a one room work space then needing sublimation printers, dtf printers/ovens, oven for larger sized projects that don’t fit in any of the presses, laser engravers and such you run of of space to actually create. Creating is the ultimate goal. I think thats why sometimes it get overwhelming to crank stuff out. It’s because crafters have unlimited imagination/creativity but it takes multiple resources to to bring it to reality.
I love this question — it really gets the imagination going. There are a few “future‑tech” ideas I’ve daydreamed about where a heat press could be the perfect tool, even if the materials or technology don’t exist yet. Here are a few of my favorites, with a little context so they make sense:
Heat‑pressed 3D shapes or sculpted designs
Imagine a special material that expands or rises in controlled areas when heated. You’d press a flat sheet and end up with dimensional flowers, ornaments, or wall art. Almost like a pop‑up effect created with heat and pressure.
Wood embossing or engraving without a laser
A press with more precise heat zones could darken or compress wood to create engraved‑style designs. Same look as a laser, but using heat and pressure instead of a beam.
Color‑changing decorative wall panels
Not the actual wall — more like peel‑and‑stick panels or framed décor made from heat‑reactive material. You’d press them once to activate a color shift or reveal a hidden pattern, then hang them like any other décor piece.
Ceramic‑style transfers without a kiln
This imagines a new type of low‑temp coating that behaves like ceramic glaze. Instead of firing a tile at 1200°F, you’d press it at crafting temperatures and the coating would melt, flow, and cure into a glossy, permanent finish.
Fabric sculpting
Some fabrics can already be shaped with heat, but imagine materials that hold more dramatic textures — raised patterns, origami folds, sculpted pillows — all locked in with a press.
Custom holographic effects
Instead of buying holographic vinyl, imagine being able to create the hologram during the press by rearranging microscopic layers with heat and pressure.
These are definitely “dream big” ideas, but that’s what makes this kind of question fun. I love imagining where heat‑press technology could go in the future.
And in terms of barriers in my workflow, the biggest one for me is alignment. I can get things straight, but it definitely slows me down. When I’m working on dark garments, layered HTV, or anything that needs precise placement, I always have to stop, measure, re‑measure, and double‑check. A built‑in alignment system — whether that’s LED guides, a projection grid, or even an auto‑alignment function — would make a huge difference.
Here are a few other areas where conventional presses could be more seamless:
Switching between materials takes time
Different vinyls and fabrics all need different temps, times, and pressures. A press that could auto‑suggest or auto‑detect settings would streamline things.
Pressure adjustment isn’t very precise
Most presses use manual knobs, so you’re guessing the pressure level. A digital pressure readout would make it easier to repeat perfect results, especially for layered HTV or thicker items. I know the HTVRONT Auto Heat Press and the H10 Heat Press have a digital display / pressure adjustment, but I’d like to see more swing arm presses have this feature.
Limited space for larger or odd‑shaped projects
Totes, pillows, long signs, and wood boards can be tricky to position. A wider opening or sliding base would help with alignment and reduce mistakes.
Uneven pressure on textured or non‑flat surfaces
Canvases, seams, zippers, and wood pieces often need pressing pillows or multiple presses. A platen that adapts to uneven surfaces would eliminate that extra step.
Heat‑up and cool‑down time
Switching between materials or temperatures can slow down production. Faster heat‑up or a rapid‑cool feature would be a huge workflow boost.
These aren’t complaints — just areas where future innovation could make the process even more efficient for all kinds of crafters.
Very well said. This is exactly what I was thinking. :blush:
Wow you got me thinking!! I would love to press on different types of bags easily. I would also heat press patches on jackets and pants. These need lots of pressing pillows lol. To have an easy to use one to put designs on walls would be cool!
There are many creative ideas that feel limited by current heat press capabilities, especially when working with thicker, uneven, or textured materials where consistent pressure and safety become an issue.
Much of the process involves time-consuming setup, alignment, and pressure adjustments, which can feel more technical and risky than creative, especially with custom work.
It would be a game changer to have heat press machines that are faster, safer, more automated, and able to adapt to a wider range of materials and surfaces, allowing more focus on creativity and less on limitations.
especially with wood materials that are uneven ! Or plastic materials that could possibly melt that regular vinyl doesn’t seem to want to stick on!
I enjoy pressing wood item the laser engraver has made things on wood fun but beyond pressing on fabrics metals can be difficult you end out with a glue ring from the htv when it’s not a sublimation project. I just like trying different things.
Very very good points (you put into words some of what I was thinking but could not get out!
Thanks! I’m glad we agree! :smiley::+1:
I would love to have something to press umbrellas on. I guess in theory I guess I could use a hat press. For the normal heat press, I would love an alignment tool on all presses.
Actually, the mini press is really a mighty tool. You can use it with most items that would be difficult to use bigger machines. You can heat press shoes, umbrellas, mugs, tumblers, boxes, wood, bottles, bags, fans, and the list goes on.
I guess items that would face difficulty in pressing are those that would likely melt and maybe those that have odd shapes
I was thinking about this a little more, and a few additional ideas came to mind that could really push heat‑press innovation forward:
Smart material fusion
It would be amazing to have materials that safely embed LEDs, touch‑responsive elements, or flexible circuits during pressing. A press designed to handle “smart materials” would open up a whole new category of interactive décor and wearables.
Built‑in safety modes for delicate surfaces
Sometimes I work on painted canvas, coated wood, or mixed‑media pieces, and I have to switch to a mini press just to avoid scorching. A “delicate surface mode” with micro‑zone heating or automatic temperature modulation would make it easier to press on sensitive materials without damage.
Hybrid pressing options
A detachable mini‑plate or modular platen system would make it easier to switch between tiny details and full‑size projects without firing up a whole second machine.
These are definitely more “dream big” ideas, but they’re the kind of features that could really expand what crafters are able to create in the future.
I would want to change my whole bedroom and bathroom with custom bed sheets, pillowcases, comforter sets, bathroom accessories like shower curtains, mats, towels, n etc. Make my home feel more unique. :smiling_face_with_three_hearts::smiling_face_with_three_hearts::smiling_face_with_three_hearts:
I may be the odd man out to bring this up but there has got to be a better way to print on cotton. I have had zero luck with the spray. I find the sublimation vinyl is very thick and the shirt just feels heavy and off and not comfortable to wear. I have a converted Epson for sublimation but again, doesn’t do direct to cotton. For us that are more hobbyists and can’t write off equipment against a business expense, I find DTF is not financially doable for the average person. If you could come up with a lasting way to print on cotton, I’m all ears but for now, I have to figure out how to do things using HTV. Cost is an issue for many hobby crafters out there.
I would love a larger or rectangular heat press to sublimate longer items like arm sleeves, lanyards, etc. Also would love if my heat press had a laser that would help me center items.
I use an oven for full wrap sublimated mugs. I would love a mug press that had like heated fingers that could be inserted under the handle to provide heat and pressure. I waste a lot of time with using shrink wrap (and money) and then burn my fingers trying to quickly remove the wrap to avoid getting it stuck.
I would also like a larger vacuum press to sublimate objects like slate.
Hmmm, sounds like you need a All-in-one heat press machine? Like combine hat, tumbler, T-shirt together. I’m wondering if HTVRONT have this product. What concerns you might have about that machine?
That’s a great insight, seriously, right now for the way to print on the cotton, except for HTV, I guess could use UV printer and use the soft ink? But still, the outcome will be heavy.
That’s really cool idea, cause I seldom think about “heat press” on mental! That’s cool, you open up my mind!
Great options. The changeable platens would really make it more versatile. All would.
