Iphone 13 mini
Is it possible to use the iphone 13 mini with the phone case heat press?
Hi, @retrogirl1961! Yes, the iPhone 13 mini works with the HTVRONT phone case heat press — you just need a sublimation case that’s specifically made for the 13 mini, or the universal fixture set. The press itself isn’t limited by phone model; the case blank and the fixture are what determine the fit. As long as you’re using a 13 mini‑sized case, it will press normally. :heart:
