Keeping a Heat Press Journal
Tip Tuesday One thing I wish I’d done from the start of my crafting and sublimating journey is keep a heat press journal. Recording settings like time, temperature, and pressure for each substrate and brand makes it easier to achieve perfect results faster and avoid repeating mistakes.
I have made a google sheet I really need to finish it lol.
wonderful idea @Katrina_Moore :hugs:
True, this is such a helpful tip! I use iCraft and add each material to my list with my preferred settings for the best cuts, then save them under “My Favorites” for easy access whenever I need them. :smiling_face_with_three_hearts:
I write all that info on sticky notes but I hadn’t thought of marking them in a journal, that’s definitely a more solid idea than sticky notes
I’ve had the same idea! I want to create my own notebook, but the process is daunting. I have to design and create it before I can start using it. That’s why I’m planning to just create a digital journal.:joy::sweat_smile:
Make sure to use the daily mission 2 tag otherwise this wont count
I’ve made one of these ages ago. It comes in handy all the time especially for sublimation. I have a template of it on my site thats free. I print out a page for each material for example HTV page and Sublimation page etc. The new LOKLiK Auto Heat Press 2 can save your most used settings for you which is cool and handy.
Heat Press Journal
Hey @bellethehowtoGuru daily mission#2 was not an option
It’s just daily mission2 you may have to type it in for it to show up
I tried that and that option was not available those were the only options I had believe me I tried typing it in
I even tried to create a new topic
@Elena can you help me with this please and thanks
You can search in the bar it shows up for me when I start typing daily
@Katrina_Moore
no problem :blush: In the search bar, try copying and pasting ‘daily-misson2’ directly to see if you can find the tag name.
Sorry, got caught up. Did you find it?
Should be able to just copy daily mission2.
Space between daily and mission and no space for 2. :smiling_face_with_three_hearts:
