Layout beyond the registration marks
Did you know? You can layout your designs beyond the registration marks, and the machine will still cut them! As you can see, my images go past the registration marks, yet the machine cuts them perfectly. This is a game changer for maximizing your cutting area!
I thought we could do that due to marks on the calibration sheets but never tried it thanks for the info
It’s nice right? Atleast we can somehow maximize the sheet but it will be way better if we could adjust the registration marks😁
You should tried can give more designs to cut even the spave under registration marks you can still put designs their
I didn’t know this.Thankyou
ok this might help me, do the registration marks stay the same whether you use 8 x 11 or 12 x 12 card stock? I wanted to make a popcorn box and the registration marks are no where near the end of the design
Registration marks cannot be adjusted yet
great tip! :ok_hand:
Welcome! :slightly_smiling_face:
How do you get registration marks then to be wider when using 12 x 12 card stock ? I set up the page format on the side I chose 12 x12 . But it continues to show I am using 8 x 11 . For example when I tried to do a popcorn box from their project selection only 3 of 4 sides printed because the 4 th side was beyond 8 inches
Print and cut is only for a4 size I think. Maybe the @admins can help
The Print Then Cut feature is not compatible with 12x12" paper. It is designed to work with standard US Letter (8.5x11") or A4-sized paper :smiley:
Also this here. I tried to find the limit of the cutting areas, but it cuts the whole sheet, even below the registration marks. It’s at least giving us this.
Yes it does and that’s great😊
Visit this comment to see the limmits explained xdd
