Loklik Crafter Not Reading Registration Marks After Update
Hi Crafters!
For those who still have the Loklik Crafter, has anyone experienced issues with the machine not reading registration marks after the update? Hoping to get some answers, as I have fellow crafters who need a solution. They have tried all troubleshooting steps but are still unsuccessful.
@admin
Last month after the 2.2.3 update I calibrated both machines
The crafter did read the marks but it cuts all in not a straight way so i had to redo the calibration and it worked.
Oh my! I hope this will be solved in the next update
I think @misshaven also had this same issue with her Loklik Crafter.
I read someone downgraded their software back to the previous version and it started working for them again. Hoping a fix comes out for it.
I think that’s for the iCraft, in the Loklik Crafter you’ll need to update both software & firmware to work properly. If you downgrade the firmware, you’d also have to downgrade the software because the reading of registration marks sometimes differ. The problem here is the proper pairing of which software works well with which firmware :disappointed_relieved:
Both should be updated software and firmware. (wala lng tlga akong masabi)
Sorry not software, I meant firmware. V10 for the crafter seems to be the best at the moment for print and cut. Yeah the latest software release for the icraft was a bit buggy I think.
I totally agree with you. I really do think there should be a table on the software page of the LOKLiK site saying what version of firmware and software is stable for which machine and which ones are still in testing phases. Would make the consumer life a bit easier
I tried print and cut with the Crafter today, in v12 the reg marks totally failed to read, reverted to v10 it was read successfully but when cutting glossy material the cuts were very much off. With regular paper, the cut was good.
Think there may be a new update coming
Hello i am so frustrated because until now my machine cant make it for print&cut
I do hope so for both machines :pray:t2: I hope they don’t leave out the v1 cutting machine when developing new updates
Have you tried downgrading to firmware version 10?
yung upper part okay noh? sa lower nalang nagkaron ng misalignment sa cuts
Baka need mag talukbong method pa din pag glossy :sweat_smile:
Hi LOKLiK Fans! We’ve seen your reports and are currently looking into it. We’ll update you once we have more details.
Thank you for noticing us :blush:
I really hope something is done since I have two Lokliks and neither will properly cut in the print and cut. Does great for vinyl bur not print and cut.
Huhu, my loklik crafter I bought mine a year ago updating the firmware still can’t make to read reg marks with glossy. I tried to dispose it and buy the new loklik icraft. but no one will buy the loklik crafter because the problems about it is very widespread accross cutting community. I wasted alot of print and cut materials just to make it work but it doesn’t work for me smoothly. :sob:
I hope loklik will make it with new versions of firmware. I am getting frustrated now. :sob:
Even with the print and cut issue, you can still make use of your machine with standard cut projects vinyls, htv, cardstock
