Loklik crafter Print and cut issue with firmware v12
For those having issues with Print and cut on the Loklik Crafter on firmware v012 my fix was to downgrade to v010.
Uppon trying to do machine calibration with Crafter v12, registration marks were always failing to read when the machine tries to read the upper right mark. I decided to downgrade to firmware v10, the machine was able to read the 2 left marks and proceeded with Print and Cut Calibration.
Regular Copy Paper was read and cut well
The only problem is when I tried to do print and cut on glossy photo sticker paper, the machine read the marks when the top cover was closed but the cuts were not well aligned.
Hope this issue can still be fixed with the Loklik Crafter :pray:t2: @admin
Oh that’s so sad it should be fixed ASAP.
I know! It’s frustrating for Crafter users
this is really helpful will try to this one
Hope it will be fixed. Haven’t been using my crafter for a while.
Thank you for the tip, I do hope the tech team can fix the issue though :pray:t2:
Have you tried using a matte transparent tape on the registration marks if using glossy paper? I have been using it as long as you apply it properly.
i tried the version 10. aint still working for me.
the software is messed up. it was okay a week ago w/ v12 but then it wont properly detect now. I think I used a ream for paper already just by testing it
