Pede po ba ang loklik machine sa magnetic sheets? If pede ano po ang setting nya?
Yes, with the right blade and settings:
Use the Deep-Point Blade Kit, which is designed for heavyweight materials up to 2.0 mm thick.
Magnetic sheets like PVC template magnetic sheets and EVA foam board are listed as compatible materials
Setup Tips for Cutting Magnetic Sheets
Blade & Pressure:
Install the Deep-Point Blade (not the standard fine-point).
Increase cut pressure and consider multiple passes depending on sheet thickness.
Mat & Placement:
Use a strong grip mat to prevent shifting.
Tape down edges if needed—magnetic sheets can curl or resist adhesion.
Design Considerations:
Avoid overly intricate cuts; magnetic material may tear or snag on tight curves.
Use the Print Then Cut feature for magnetic bookmarks or stickers with clean outlines B.
Recommended Cutting Force for Magnetic Sheets
While LOKLiK doesn’t publish an official preset for magnetic sheets, based on user tests and comparisons with similar machines, here’s a solid starting point:
- Cutting Force: 500–600 grams
- Blade Type: Deep Cut Blade (60°)
- Passes: 2–3 passes (depending on thickness)
- Speed: Slow (to ensure clean edges)
- Mat Type: Strong grip mat (to prevent shifting)
These settings are ideal for thin magnetic sheets used in crafts like fridge magnets or bookmarks. If you’re working with thicker or adhesive-backed magnetic material, you may need to increase the force slightly or add an extra pass.
Thank you so much❤️
Yes thank you, I have a couple of sheets but didn’t know what to do with them. At least I know the cutting info when it comes time.
